throttle part
Post your wanted adds here
seagull101
throttle part
Post by seagull101 » Sun Oct 01, 2017 7:42 pm
Im after the part that goes on the throttle cable on SD's and Marstons.
My SD has it as its got the original cable but the OP does not.
If somebody has the part or a knacked cable with it then i would be interested in buying it.
Jacob
Re: throttle part
Post by headdownarseup » Mon Oct 02, 2017 6:24 pm
Have you got enough adjustment left at the top of the slide cover to take up any slack in the cable?
If not try something like this
http://www.classicseagulls.co.uk/index. ... uct_id=396
Failing that, if you've got a bicycle repair shop near you, they might have something that will work.
Or try John of course
