Crank and Pistons are the same?
african imp
Post by african imp »
My next Seagull engine build could be a Century or a 102, it depends what parts turn up in the future?
I have a question, the two crank cases I have are both stamped with Silver Century engine numbers.
Would the crank and piston from the 102 series fit the same crank case, as in are they the same?
fleetingcontact
Re: Crank and Pistons are the same?
Post by fleetingcontact »
The pistons are the same although I remember an old thread that asserted new piston rings were too wide for a new piston. Further, some assert that the profiling of the original 102 pistons, a little different to the 'modern' (modern - lol) offering, is more efficient. Its a bit academic though, unless you come across a usable old one.
However, with regard to the crankcases, this is a question I asked quite recently; have a look in the 'Help' section where blokewithaboat gave some helpful info.
african imp
fleetingcontact wrote:The pistons are the same although I remember an old thread that asserted new piston rings were too wide for a new piston. Further, some assert that the profiling of the original 102 pistons, a little different to the 'modern' (modern - lol) offering, is more efficient. Its a bit academic though, unless you come across a usable old one.
Thanks, I will check out the Help section !
