Do I really need another seagull.
The motor was pretty local and it was cheap enough, it may get some use on the boat.
Most likely it will be moved on, as 1979 is I little modern for me, I will see.
Re: Do I really need another seagull.
Has the throttle cable got a kink in it?
The owners manual ought to contain a statement saying. "Do not thread the throttle cable through the dooberry on the tiller arm casting!"
I think they're a lovely Seagull, Keith, worth keeping!
The cable is fine, I made it about an hour ago.
seagull101
Post by seagull101 »
Yep Chas, they look good on display motors but are no good on motors that get used.
