Serial No Defaced
philiphenson
Serial No Defaced
Post by philiphenson »
I just bought a Silver Century on Ebay. A rather impulsive purchase but it was nearby, I was bidding in the last few minutes of the auction so didn't have time to email the seller.
On getting it home today I find that the serial number has been partially removed - see photo. What does the forum think? I can only think of one reason why someone does this.
I wonder if I should report it to Ebay?
Philip
My Guess is WSL 806EE7
Re: Serial No Defaced
Grand theft auto comes to mind.....
Personally l wouldn't worry about it. Just part of its colourful past. Hope it doesn't run too hot :lol:
There is another possibility this looks like it could be one of the crankcases with the lower main bearing that protrudes from the case into the drive shaft tube & is quite a tight fit in there, to remove the power head often requires a few clouts from a hammer, as this is the side with the best access it's the best place to rest a drift when hitting, if you don't have a rubber hammer.
I doubt very much if a Seagull is at the top of an outboard thief's hit parade, as it's worth more as parts!
difficult to confirm one way or another, I would just accept it as is and enjoy owning it.
Maybe not the right attitude, would you think the same if one of your motors went walkies, or is it just a seagull.
As seen on Ebay, Stolen: British Seagull 102, Brighton, good chrome on exhaust, faulty magneto AC14127, this was someone pride and joy.
As for as this motor is concerned, the serial number has tried to be rubbed out, to what end and why, we will never know.
30 seconds with an angle grinder & it would be illegible, you can still see most of it!
WSL * 08 EE7
That was a quick look, your screen is bigger than mine Keith, what say you?
I thought as Charles did at first but when you expand the photo the number has clearly been targeted.
Grumpy
Post by Grumpy »
I just can't imagine that there is anything false or illegal about this seagull and the thought of people dealing in hot ones is unacceptable.
Plus I have never ever heard of or seen a bent Aussie. Like finding a 3 legged kangaroo. I sure hope no one on board here is insulted or feeling uneasy.
Cripes.
Over the years I have seen and heard of marinas being cleaned out over a weekend, so it happens far more often then people think and most seagulls are just kept in a shed at the bottom of the garden, but some of us have the sense to keep a record of serial numbers.
As far as bent Aussie's, I've never been into rugby.
Gannet
Post by Gannet »
Moving a little bit away from the topic of the defacing of this specific serial number, yes, I think a record of the serial number is critical. A photo of the outboard showing the serial number could also be possibly useful. But what about marking the engine somewhere in a non obvious place to identify it as yours. Is that a good idea or not really useful?
I can't think of a better way to make a Seagull look dubious & only 8 hammer blows!
If I was robbing a marina I'd only pick up a Seagull if I still had room in the car & all the good stuff was in there already!
