Seagull remotes
Seagull remotes
Hi my Mercury 40 blueband packed in and I have now replacing it on my Dejon 14" boat for fishing with... wait for it.. YES a Seagull 100 with clutch. (I know its not as powerful, but won't break down every few trips) My Seagull 40 plus has been used as a backup a lot during 2016
My question is has anyone fitted remotes to a seagull (Perhaps bolted something onto the tiller) I am going to try and come up with some ideas
Re: Seagull remotes
When you say remotes are you talking about remoting the throttle or the steering or both?
Remote steering photo's
If you click on the link below, you will be redirected to my flickr account and I have uploaded some photographs of my hook up to a teleflex steering system. Hope this helps. It is basically using a seagull engine mounting lug and a piece of steel and a few washers for strengthening and a stainless steel swivel jaw and jaw.
https://www.flickr.com/gp/151850923@N05/o8471m
Engine mounting lug
http://www.saving-old-seagulls.co.uk/bu ... spares.htm
https://marineparts.ie/above-deck/shack ... d-jaw-6mm/
Engine mounting lug
Re: Seagull remotes
What happens when you tilt the motor Pat?
Re: Seagull remotes
I didn't know I had to tilt the motor?
Can you elaborate a bit, what exactly you mean.
It works fine for me anyway, it's got full movement left and right, but I just use the boat on the canal.
Re: Seagull remotes
I went out and tilted the motor and it would not clip in to the "lugs" that hold it at different angles due to the addition of the engine mounting lug that raises the height of outboard by the width of the engine mounting lug. I guess maybe the propeller may not be pointing at the correct angle when in the water?
All I can say is that boat pushes along nicely on the canal with the angle that the outboard is currently set at.
The boat is a Norman 17. Picture below (not my actual boat)
Re: Seagull remotes
Finally I worked out how to post pictures on the forum with the "flickr" account. You need to use the "bbcode" function and copy the link.
WP_20170620_19_56_45_Pro by pat seagulldexta, on Flickr
WP_20170620_19_58_55_Pro by pat seagulldexta, on Flickr
Re: Seagull remotes
That's a clever adaption. Well done.
Re: Seagull remotes
....patent pending!Hugz wrote:That's a clever adaption. Well done.
Re: Seagull remotes
Its for steering really, but have the cables for throttle also.pat777 wrote:When you say remotes are you talking about remoting the throttle or the steering or both?
Re: Seagull remotes
Hey thanks Pat. That looks perfectpat777 wrote:Finally I worked out how to post pictures on the forum with the "flickr" account. You need to use the "bbcode" function and copy the link.
Re: Remote steering photo's
Thanks. Is the lug for a 40 ?pat777 wrote:If you click on the link below, you will be redirected to my flickr account and I have uploaded some photographs of my hook up to a teleflex steering system. Hope this helps. It is basically using a seagull engine mounting lug and a piece of steel and a few washers for strengthening and a stainless steel swivel jaw and jaw.
Engine mounting lug
Re: Seagull remotes
Just make sure that if you go along with this method, that the engine mounting lug is not fouling the clutch lever.
Also depending where your teleflex steering system is currently coming out at the transom, it may need moving to line up right with the stainless steel swivel jaw and jaw.
Mine is free moving and "in line" and not under any strain.
And finally it is quite important to strengthen up the engine mounting lug with a piece of steel as it is quite thin in places and I'm not sure how long it would last without the additional strengthening.
WP_20170620_19_58_21_Pro by pat seagulldexta, on Flickr
Re: Seagull remotes
Thanks again.pat777 wrote:Just make sure that if you go along with this method, that the engine mounting lug is not fouling the clutch lever.
Just bought a lug on ebay a
and looking at these.
https://www.s3i.co.uk/swivel-jaw-jaw.php
I guess its the 8mm one.. Will need to check my steering rod. Mine is similar to that only comes in from the starboard side
Re: Seagull remotes
The motor needs to tilt when you hit a supermarket trolley or any other underwater obstacle & you still need to steer afterwards, more so in a canal with hard banks & boats coming towards you.
Look at all the Seagull racing pics you can find, many have wheel steering & remote throttles.
I doubt the safety scrutineers would let you run yours as when you hit an obstacle & the motor tilts it will try & lift the transom bracket off the transom!
