Throttle Cable
outboard
Throttle Cable
Post by outboard » Mon Sep 19, 2011 9:37 pm
Can anyone tell me how I'd go about getting an extended throttle cable suitable for a 40+ if I was trying to fit my Seagull to a steering system?
Re: Throttle Cable
Post by Hugz » Mon Sep 19, 2011 10:38 pm
Easy enough to make your own. Buy some cable and sheath from your local bike shop. Mention it is for a tandembike if you wish it to be extra long. Make a mould of the existing two ends (though you may find a bike break end will fit into the throttle lever with a small bit of filing) using clay, plasticene, dental materal etc. Clean and tin the ends of cable and then fill your mould with molten solder whilst dipping the end of cable in while applying heat.
outboard
Re: Throttle Cable
Post by outboard » Tue Sep 20, 2011 7:34 pm
Cheers Hugz, great bit of information, and easy to understand. Being a dental technician I work making moulds daily.
Re: Throttle Cable
Post by Horsley-Anarak » Tue Sep 20, 2011 7:52 pm
outboard wrote: Being a dental technician I work making moulds daily.
Mercury amalgam or gold for the cable ends?
Use gold then it will be a very valuable seagull :)
outboard
Re: Throttle Cable
Post by outboard » Tue Sep 20, 2011 9:45 pm
Amalgam sounds good. It's harder and a wee bit cheaper than gold.
Re: Throttle Cable
Post by Charles uk » Tue Sep 20, 2011 10:07 pm
Tandem gear cables are 2100mm long & have stainless steel inners, that you have to use Laco acid plumbers flux to solder or silver solder the throttle lever nipple in place, they all ready have one almost the right size for the carb.
outboard
Re: Throttle Cable
Post by outboard » Wed Sep 21, 2011 8:38 pm
Thanks guys, now know where I'm going.
