Retrofit sealed gearbox onto forty
forestcreature
Postby forestcreature » Thu Aug 02, 2018 12:42 am
Is it possible to retrofit a lip-seal gearbox (or housing?) onto an unsealed forty?
I know I read a discussion about this, but I am really sorry that I can't remember where or what the outcome was
fleetingcontact
Re: Retrofit sealed gearbox onto forty
Postby fleetingcontact » Fri Aug 03, 2018 5:16 am
The water-pump housing is a different design to the fixed-drive equivalent, so if you go for it the result would have non-standard driveshaft casing and driveshaft lengths. Thus:
...cut the driveshaft casing tube to length
...cut the driveshaft to length
...drill and tap the driveshaft casing to accept a engineering stud
...mod a clutch rod to fit
And another thing - the driveshaft casing diameters are fractionally different so you may need a tube from a clutched model anyhow, which would at least save the bother of tapping the fixed-drive casing.
Or buy a clutched model.
forestcreature
Postby forestcreature » Sat Aug 04, 2018 5:31 pm
Thank you! I agree with the last sentiment then. Not that the work is too awful to consider but there seem to be enough Seagulls around!
Return to “General Topics”
Who is online
Users browsing this forum: No registered users and 30 guests
