Charles uk wrote:It would appear from your pictures that the insulation on your HT lead is in a very poor state, why not look at a repair above the baseplate where the insulation is more protected & should be in better condition, then all you need to find is the right sized copper cored HT lead & some method of connecting them, the joint will then be better protected from vibration as it will be supported quite closely at both ends.
The insulation is very bad at the end all right, there is no noticeable damage after the first few inches. I agree it would be better to have the connection above the base plate under the flywheel for both the support and the weather protection but I think it might be a bit of a fiddly job trying to get the connection right in the confines of the flywheel. (I'd be worried about straining the joint when it comes to pulling the
lead back through the grommet on the base plate. You'd only really get one chance to get it right also where as if I keep it below the base plate if the first attempt doesn't work I can just cut another bit off the existing
lead.
I'm hoping with the adhesive lined heat shrink that I will have a fairly secure joint that will be protected from the elements and the vibration. Thanks for putting forward the idea though, it's good to consider different options when it comes to these bodge jobs.
This sort of repair should be ok for frendly river use but might not be quite as suitable for crossing the Irish sea!
That sounds like a challenge to me! I'm not sure the RNLI would be too happy with me heading off across the channel with my "trusty seagull". If I leave now I may make it in time for the Essex Flocking. I think I'll stick to the safe option cruising up and down the canals.
John might have the right sized HT lead have you tried him?
John must have Charles uk on commission for all of these referrals! I'll try and get some
lead locally but if I have no luck I'll get in touch all right. I know I haven't got a hope of getting the 4mm locally but I'm hoping one of the local motor factors will have some 5mm that will hopefully do the (bodge) job
Cheers Pat
