Any suggestions?
Paul Joppen
Any suggestions?
Post by Paul Joppen » Mon Sep 30, 2013 10:23 am
Hello,
Last week I bought a nice and complete 1951 102 series AD. Now I want to spend the winter months building a wooden boat from one of the plans that can be bought from Internet. The boat should be approx. 12 feet long and weigh no more than 50 kgs/ 110 lb. so that it can be lifted into and out of the water by two persons. Does anyone has suggestions? I would prefer a nice elegant and classy shape like a skiff.
All the best,
Paul.
The Tinker
Re: Any suggestions?
Post by The Tinker » Tue Oct 01, 2013 9:14 am
Check this one out goes real good with a Seagull also rows well and is easy to build
http://rosslillistonewoodenboat.blogspo ... -boat.html
denchen
Post by denchen » Tue Oct 01, 2013 4:46 pm
Over the summer I built a 16ft canoe for the grandkids. Its extra wide about 4ft 2ins and I built it of 18mm x 3-4mm strip pine covered both sides with 300gms woven glass. The bottom line is it is very light for its size and is very strong. This next summer I have been toying with building another boat to replace my small dingy with a Stuart Turner 1.5hp that has seen better days. If I do I will probably go for the 18mm x 3-4 strip and not bother with any timbers (ribs) but some gentle curves in her as many as I can.
Paul Joppen
Post by Paul Joppen » Tue Oct 01, 2013 8:26 pm
Hello
@ The Tinker: thank you very much for your suggestion. I didn't come across the plans of Ross Lillistone before. Indeed a very beautiful boat that would fill the bill. The photographs show Steve Dorrington with a 40 plus with an extended tiller. Wouldn't the extra 6 kg/10 lbs of a 102 not be a problem?
@ denchen: at first I would love one of the canoe designs with a square stern but I am a bit bothered that they haven't enough displacement nor a wide enough stern to manhandle the 18 kg/ 40 lbs of the 102.
I found a design on http://www.tangoskiff.com. The extended stern should solve the problem for a smallish lightweight boat with a fairly heavy engine. The plans are very well executed.
All the best, Paul.
phil
Post by phil » Tue Oct 01, 2013 9:42 pm
www.svensons.com/boat/
Lots of free older boat plans here.
The Tinker
Post by The Tinker » Wed Oct 02, 2013 9:09 am
Flint goes well with Silver Century on the back and two biggish people plus food and 15 litres extra fuel
Post by Charles uk » Wed Oct 02, 2013 9:53 am
I agree with Tinker 100%, Flint is an elegant, proven, low cost, simple to build Seagull type hull, that should be easy to get to or better, your target weight, 12 feet / 50 kilos.
denchen
Post by denchen » Wed Oct 02, 2013 4:33 pm
Have you thought of building a boat with a raised hole to drop an engine in, then a rudder at the stern to steer. Just throwing ideas in. Use your seagull as a power unit only, as long as you don`t hit bottom when coming back to the beach.
Paul Joppen
Post by Paul Joppen » Thu Oct 03, 2013 8:59 pm
Hello Denchen,
Like in a motor launch.... What a great idea. Would look classy too. The Flint is really a nice design. It has a nice wide stern to carry the engine. Does anyone know what its displacement is?
I bought the plans of a 15' Dinghy from Morten Solesen at http://www.boatplans.dk. It has quite a small stern but the designer offered to modify the plans. He also sells fully CNC-ed kits at a competitive price. I am considering one of those.
All the best, Paul.
